OK so this is my set up :
Allen and Heath Xone 42 (Using as external mixer)
Pioneer CDJ-400(supported by vdj)
Numark ICDX(Supported by vdj)
Also i have 1 numark DJ Io
A laptop with 3 available USB ports
What i want to do is to be able to control both my decks separately on VDJ and have the audio outputted onto the xone 42 on 2 different channels. What iv been able to do so far is only have one channel on the xone 42 responding to the tracks being played and both my decks can only control the same track and i cannot use them simultaneously ( if i hit play on the CDJ it hits play on the ICDX). I have my DJ IO and my decks connected to the laptop with both outputs in the DJ IO connected to the Xone 42 (channels 1 & 2). Also i keep getting an ASIO error saying not enough channels. What can i do to fix my problem and have both my decks work the way they want to and have both outputs on different channels on my mixer? (also if id have to purchase something to fix this what would it be?)
Sorry if this post is poorly typed.
Please help
Thanks
Please help
Thanks
geposted Thu 28 Jan 10 @ 2:48 pm
Try Useing A ESI GigaportHD It Has 8 Ch Or A Sound Card With More Then 4 Ch.1chLeft & Right/ 2ch Left & Right
i
i
geposted Thu 28 Jan 10 @ 5:51 pm
