i bought the DMC2 last year and is the best thing i ever had...but now i'm starting to have trouble on one of the cue button, i have to press it really hard to cue the songs....
is thier any kind of way i could fix this????????
CAN SOMEONE HELP ME???????
geposted Thu 28 Jan 10 @ 3:01 pm
Your Dmc-2 Has Problems. I Have A Dac-3 ( PCDj ) And It Was Doing That And I Had To Seen It For Repair And Update.
geposted Thu 28 Jan 10 @ 5:43 pm
Yes, sell it and buy an American DP2.
DMC2 is a great controller but has serious troubles with the buttons. I had one for 2 years, with medium use, and the buttons became a real pain.
geposted Thu 28 Jan 10 @ 6:19 pm
Hi mate
The switches are an issue with the DMC2 but they are also easy to replace and very cheap to buy. If you are handy with a soldering iron you can do it yourself. If not it is not a big job to have a repair shop sort out for you.
Daz
Daz
geposted Fri 29 Jan 10 @ 12:13 am
I suspect your CUE-button suffers from excessive pressing...just like the ?-key of your keyboard ;)
geposted Fri 29 Jan 10 @ 11:55 am
THANKS TO ALL U GUYS FOR THE HELP....I REALLY APPRECIATE
geposted Fri 29 Jan 10 @ 12:12 pm
Spraying the micro switches with switch contact cleaner/lubricant will usually fix this problem, however it does involve taking the controller apart.
If it is still under warranty then you should return it for repair/replacement.
geposted Fri 29 Jan 10 @ 12:21 pm
