Can someone tell me if you can set a variable with a value from "get active_loop" and then use it later on in the same script. I am trying to Get the active_loop size and then move the loop by the amount of the active_loop size. My code looks something like this:
set 'myLoop' to get active_loop & loop_move get var 'myLoop' & loop get var 'myLoop'
geposted Fri 29 Jan 10 @ 2:10 am
Sorry, this is not currently possible.
The results of 'get' cannot currently be stored in variables or substituted as the parameter to another action.
geposted Fri 29 Jan 10 @ 12:22 pm
Thank you for your response! :)
geposted Fri 29 Jan 10 @ 2:35 pm
