OK, it seems as if I am finding all of the \"never seen before\" issues and here\'s another I believe.
Yesterday all was working well on my software and all of the sudden without making a change I lost all sound output on deck 1 when moving the jogwheel backwards. Deck 2 still has sound output forward and backward but deck 1 does not. This issue happens ragardless of using the mouse on the jogwheel in the software or using my 3700\'s. If I activate the \"backspin\" effect it has sound but not if i try to do it manually.
I\'ve shut down and restarted the whole system and then also restarted without my 3700\'s connected and the issue remains.
Anybody have any idea? Numark\'s support was less than worthless :(
geposted Fri 29 Jan 10 @ 3:08 pm
You have the smart scratch turned on .. flip the FWD/BOTH switch a couple times. And make sure it is on BOTH.
geposted Fri 29 Jan 10 @ 3:54 pm
hmm, I flipped the switch back and forth but I'll check that out too. Thanks.
geposted Fri 29 Jan 10 @ 4:51 pm
Sadly, I report that didn't change anything. I flipped the switch back and forth like well you know and nothing changed. Is that a setting in VDJ/Cue that I am missing?
geposted Fri 29 Jan 10 @ 5:11 pm
