Hi,
I'm having some issues with the crossfader keyboard shortcuts on VDJ.
I want to be able to snap the crossfader from one deck to the other (default command is ctrll+page up/ctrl+page down), but this doesn't seem to be working. I've checked that the commands are in the shortcuts list and tried re-assigning them to other keys too, but this hasn't worked either.
All the other keyboard shortcuts work perfectly, it's just the ones for snapping the crossfader to either deck. I can gradually fade using page up and page down as normal and my keyboard is working fine in other programs. If I re-assign the keys using the "key learn" feature the program "learns" the keys as normal, but it doesn't actually work once I close the config window.
Can anyone help?
Thanks in advance
Can anyone help?
Thanks in advance
geposted Sun 31 Jan 10 @ 9:09 am
post a copy of the commands your using here..
geposted Sun 31 Jan 10 @ 10:44 am
I'm using the default keyboard shortcuts:
http://i47.tinypic.com/2mxk5xd.jpg
Hope this helps.
Thanks
Hope this helps.
Thanks
geposted Mon 01 Feb 10 @ 3:20 am
