Awhile back I think in 5.2, I had a problem with a different type of zip file that was not supported by vdj. I'm not sure what type it was or if there are abunch of different kinds. Was this fixxed by any chance in the new versions of vdj?
geposted Sun 31 Jan 10 @ 1:19 pm
Although I haven't heard anything lately, I think they still need to be zipped using standard compression. MP3+G Toolz.net is good for this when it is set in options->zip compression to level 5-default compression. You can do your whole collection at once in two steps (large collections take awhile):
I hope this helps ;)
- UNZIP (convert zip to Audio+g)
- REZIP (convert Audio+g to zip)
geposted Tue 02 Feb 10 @ 9:00 am
Yep, that's what you need to do..and that will fixit.
6.5 play them well providing their not to compressed.
Good Luck
Joey....
Good Luck
Joey....
geposted Tue 02 Feb 10 @ 5:07 pm
Thanks guys. I got it to work , but I still cant use vdj on my new laptop cuz freeze issues so I had to use another vid software. Works perfect tho on my xp machine.
geposted Tue 02 Feb 10 @ 5:51 pm
