I'm running 5.2 and RMX, all works well with my Serato vinyls for a few minutes. I have a good code signal and i can play with them and scratch well, the problem that i have is that as the needle reaches the end of the vinyl I pick up the needle and put it at the start of the record .When i do that, the music will not respond to what I do on the turntable. If I stop the record or scratch, I can see the display turntable on the screen react and do what I do, but the music doesnt. I've tried to hit the stop button to stop the tt and then pick up the need and move but as soon as start it again, the music will not respond. Again, I can see that the signal is working because it still reacts to movement and confirmed on screen but the music does not.
Any ideas or suggestions?
geposted Mon 01 Feb 10 @ 2:37 pm
