I have no sound from my headphones when using Cue. But sound comes out fine on vdj. Can anybody shine some light on this issue?
geposted Mon 01 Feb 10 @ 10:42 pm
anybody?
geposted Tue 02 Feb 10 @ 2:06 pm
What sound card are you using? Did you select "Outputs: two" in the VDJ config/sound set up tab?
geposted Tue 02 Feb 10 @ 2:07 pm
You need to select:
Inputs: None
Outputs: Headphones
Then select either 2 cards and select the two M-Audio Xponent options, or select ASIO and the M-Audio Xponent ASIO.
Inputs: None
Outputs: Headphones
geposted Tue 02 Feb 10 @ 3:51 pm
Thanks guys. I reallized my mistake and it now I have sound. Thanks again.
geposted Thu 04 Feb 10 @ 4:40 am
A lot of the fixes for this particular problem seem to be for older versions of vdj and I was wondering what the fixes for this would be in vdj 8? Ive tried messing around myself to fix this and tried a lot of the fixes that worked for older versions but nothing is panning out so far.
geposted Sun 08 Feb 15 @ 8:00 pm
Home Users are not permitted to post email addresses.
geposted Mon 09 Feb 15 @ 3:58 am
As stated, this information is outdated. Please start a new thread on this subject.
geposted Mon 09 Feb 15 @ 12:45 pm
