hi im a newbiee at this so here goes i have hercules mp3e2 rigged to pc then pc to sound card which is then connected to amp. when i connect all this and then put numark cd1 into amp i gett really bad volume drop
do i have to invest in another amp or is there a way round this.
thanx
thanx
geposted Tue 02 Feb 10 @ 4:18 am
Turn of the amp while putting in the connectors. Afer connecting turn it on. ;-))
Greets, Heiko
Greets, Heiko
geposted Tue 02 Feb 10 @ 4:29 am
thanx will try
Is the amp designed for multiple inputs? If not, maybe a basic mixer will help.
geposted Tue 02 Feb 10 @ 8:35 am
What is the model of your amp?
geposted Tue 02 Feb 10 @ 9:57 am
my amp has mutiple inputs as i said i tried but still loss of volume the make is a kool sound sx-400 will having a basic mixer help?
geposted Wed 03 Feb 10 @ 12:59 am
If you need to connect two pieces of equipment, then yes.. a mixer of some sort is the only way to go...
Your power amp DOESNT have multiple inputs, it has two TYPES of inputs, wired in parallel.. one 1/4" connection and one XLR connector..
Its simply not setup to be used for multiple inputs.. (the lowered volume can happen any time two 'line level outputs' are directly connected to each other.)
You dont need a fancy mixer.. any 2 input (stereo) or 4 input (mono) mixer will be fine..
example might be BEHRINGER XENYX 1002 .. Its not a dedicated DJ mixer, but would work perfect for now, and would still be usefull for other things if you ever upgraded to something bigger and better..
http://www.behringer.com/EN/Products/1002.aspx
geposted Wed 03 Feb 10 @ 10:24 am
When you add a mixer to your setup, you have more control over the volumes of your input sources, whatever they may be. So, a mixer is a good addition to the system for that reason.
geposted Wed 03 Feb 10 @ 11:52 am
thanx for that will get one sorted found that it was internal soundcard of pc changed pc no sound drop thanx for the advice.
geposted Thu 04 Feb 10 @ 6:19 am
