ok so earlier, i recored a mix and it worked fine. no problems.
so i close down virtual dj. about 30 mins later, i come back on. try to record another mix and i get something that looks like this:
**Record Error**
Video codec not found
any help would be brilliant as im puzzled!
Thanks
**Record Error**
Thanks
geposted Wed 03 Feb 10 @ 6:55 am
nevermind just sorted it.
geposted Wed 03 Feb 10 @ 7:35 am
how did you manage 2 sort it
geposted Thu 04 Feb 10 @ 12:57 pm
**Record Error**
Thanks
**Record Error**
Thanks
Tell us what codec you used to record your video mixes...:)
geposted Thu 04 Feb 10 @ 3:03 pm
I downloaded the divx video codec for free @ http://www.divx.com/en/downloads. Then in VDJ under record tab click on config... type in divx for the codec. I also changed divx codec to Windows Media Player Video Recorder in settings under codec tab.
geposted Sun 14 Feb 10 @ 2:02 pm
Thankx Instantrequest,
you are a life saver.... your instructions worked....:)
Big Up
DJ Omar
Big Up
DJ Omar
geposted Fri 26 Feb 10 @ 2:49 am
We should add a Wiki entry one day on this..
lots of questions regarding it..
geposted Fri 26 Feb 10 @ 9:51 am
i've seen it do this, going back through the select steps using the Reg editor will fix
geposted Sat 27 Feb 10 @ 7:49 am
yeah this should be highlighted somewhere, i can finally record video lol
geposted Sat 27 Feb 10 @ 4:46 pm
Hi , I just installed the codeck and had select it on vj (No Registry Tool used) I do start recording afther some seconds I Have Fatal Error
Can u Help why this happen?? thnx
geposted Tue 09 Mar 10 @ 7:36 pm
might be a resolution error..
The thing about using a window, is its hard to get a resolution bigger then 320 X 240 .
and if you attempt to resize the window, its always turns out to be a different #.
geposted Wed 10 Mar 10 @ 9:29 am
