Hello everyone...
I just bought (downloaded) Virtual DJ PRO for Macintosh and I can't seem to be able to broadcast and listen using the URL that the program says to tune into.... the URL is ---- http://70.149.219.206:8000/VirtualDJ.mp3 ---- This page can not be found it says.
What am I doing wrong? Do I need to install something else to be able to stream live music?
Your help will be greatly appreciated... Thank you in advance!
Dan
geposted Wed 03 Feb 10 @ 9:31 am
i dont know if this will be any help but there is a great program i use called - Nicecast http://www.rogueamoeba.com/nicecast/
I recommend using a separate program for streaming and leaving VDJ to the Dj'ing.
I also recommend (depending on how many viewers) using a company (or similar) like http://www.internet-radio.org.uk/
Pay as you go Bandwidth, so you upload your stream to the control panel and then clients connect to this server, thus meaning your clients and listen to fantastic audio streams without clogging your connection.
This is what i do anyway :)
geposted Wed 03 Feb 10 @ 3:44 pm
