can anybody shed some light on this matter ive tryed 2 record a set but it says error cant find codec for mpeg4? has anybody else had this problem ive got version 6 pro does everybody have this problem or has this been sorted in later versions im running the software on sony vaio laptop (vista) every thing else works fine just this slight glitch
geposted Wed 03 Feb 10 @ 10:00 am
hello is anybody out there
geposted Thu 04 Feb 10 @ 12:52 pm
geposted Thu 04 Feb 10 @ 12:53 pm
what version are you using?
IE: 6.x ... whats the 'x' ?
geposted Thu 04 Feb 10 @ 2:54 pm
just the original 6.0 pro which should i up grade 2
geposted Sat 06 Feb 10 @ 12:44 pm
i'm assuming then your running a cracked version?
If so, your probably fragged no matter what you do.. each cracked version has their own weird issues..
geposted Sat 06 Feb 10 @ 2:54 pm
no its brought & payed 4 ive just up dated it 2 version 6.6 hopefully the bugs are fixed now
geposted Sat 06 Feb 10 @ 6:09 pm
ive seen alot of people with the same issues with newer versions aswell so its down 2 the software surely
geposted Sat 06 Feb 10 @ 6:11 pm
ps ive downloaded xvid for this installed it went 2 main config typed xvid with video decoder in the box next 2 it then went to record config & typed in xvid as the codec it started recording then freezes up compleatly with white screen luckly a box pops up 2 close down vdj i just need a solution that works im thinking of getting adobe premiere pro 2 do my video mixing its gonna cost $700 usd just pi$$ed off that im having to fork out more money but i,ll get better results
geposted Sat 06 Feb 10 @ 6:38 pm
I'm curious (please forgive me), but how did you update to the newest version even though your username shows up as a non-licensed user?
geposted Sat 06 Feb 10 @ 7:18 pm
