HEY!
The numerous stories about the conectiv drop outs got me wondering.. is there anyone who has experienced it and fixed that problem?
Thanks on behalf of all conectiv owners!!
geposted Wed 03 Feb 10 @ 4:01 pm
Haven't had any problems.
geposted Wed 03 Feb 10 @ 4:04 pm
Yea I found out why!
Apparently the conectiv uses up to 500ma of power and most laptop can supply UP TO 500ma of power on USB ports.
So if we get an AC adapter, the drop outs won't happen. This goes out to all conectiv users!
BTW If jasper1234 is reading this, where you using an AC adapter during your gigs? Maybe thats why!
Thanks!!
Thanks!!
geposted Wed 03 Feb 10 @ 4:09 pm
no i wasn't using one ive decided to go with the VCI 300 tho i getting out of the timecode era thanks fo rthe tip i will pass it on the the guy thats buying my gear :)
geposted Wed 03 Feb 10 @ 4:13 pm
Haha alright.
Is there another reason why you left timecode? Was it delayed response from the moment you move the platter? I'm guessing you where using vinyl?
geposted Wed 03 Feb 10 @ 4:22 pm
yeh i was using vinyl i dj alot of weddings and events and i just dont wanna lug around gear anymore ex two tech 1200 mk2 a ddm4000 mixer my maudio connectiv soundcard timecoded vinly ect this VCI 300 will do it all and its very stable i havent heard of anything going wrong with them and it will blow ppl away with what i can do with it also the new effects midi VFX-1 that goes with it is amazing too ive used timecoded vinyl and vinyl for years i have also used cdjs and basicly the vci 300 is the same thing as cdjs except its not as expensive and its more reliable i can not afford cdj 2000s right now but in the future i will buy them so the vci 300 will tie me over until i can buy cdj 2000s
geposted Wed 03 Feb 10 @ 4:37 pm
You don't understand how useful this is man..
Did you have delayed response to scratching? Or were you more of a mixing DJ?
Also, are you planning to do turntablism moves on your VCI 300?
geposted Wed 03 Feb 10 @ 5:07 pm
iam just a mixing dj not a scratch dj i spin electro house and use ableton live with the vci 300 and itch
geposted Wed 03 Feb 10 @ 5:33 pm
