Hi freinds it seems as though when I load a song it skips aheads to a beat that is off trackwith a beat I am trying to mix. Is there a setting I am missing?
geposted Wed 03 Feb 10 @ 8:20 pm
Maybe you have AutoCue on?
Go to config->options and check...If it's on, try disabling, then load a song to see if it behaves the way you like.
geposted Thu 04 Feb 10 @ 2:26 pm
I had a similar problem where it would clip the start of a song from time to time. I discovered I had the feature "smart_play" enabled..Taking that off solved my problem.
geposted Fri 05 Feb 10 @ 5:53 am
