ok ive recently used a friends vinyl decks and much prefer using them to my well limited pc djing BUT im not rebuying all my records
i dont like serato
what do i need to get set of turntables and a mixer working with VDJ ?
the laptop im using has 1 audio output which is conected via mini jack to rca to my amplifier
been looking at these turntables and mixer
http://www.htfr.com/more-info/MR293537 (mixer)
http://www.htfr.com/more-info/MR152799 (turntable)
but im lost on what else i need any ideas
also can u still use the software to dj if the decks are connected??
i dont like serato
geposted Thu 04 Feb 10 @ 12:26 am
Hey there again, I've been furiously researching the whole DJ topic for the past month or so & from what I gather this is the breakdown.
Correct me if I'm wrong, I just want to make sure I understand the setup you're going for. You primarily a PC DJ, all of your music is on your laptop in some shape or form, but you now want to expand your versatility & start using turntables & a mixer...correct?
there are two additional components you will need to make this all work. Lets start with what you have (& are looking at), you PC with the VDJ software & music library, a two line sound mixer & two turn tables. On top of that you will need a sound card, which in the other post I suggested either a Maya44 or two Behringer UCA202 (I'm still not sure if CDJ can handle two ASIO cards at once, if not the Maya44 will do just fine). Lastly two Time Code Vinyls, one for each turntable (they run about us$10-20 each)
For some line by line instruction I suggest the setup video by DJ Socross...quite entertaining as well.
http://www.youtube.com/watch?v=hrYIpZ1h29E
I'm quite sure I've covered everything as best I could as a beginner. I hope I understood your desired setup & that the instructions I gave have been helpful.
Mix On!
--BBB
Mix On!
--BBB
geposted Fri 05 Feb 10 @ 12:10 am
thank you :)
geposted Fri 05 Feb 10 @ 7:08 am
Sure thing, seeing how I haven't been corrected I'll take it that I answered the question in full. Unless there is anything I missed & someone with more technical knowledge can fill in for anything I missed.
Glad I could Help.
--BBB
Glad I could Help.
--BBB
geposted Fri 05 Feb 10 @ 11:58 pm
i just wanted to confirm i was right! :)
geposted Sat 06 Feb 10 @ 1:33 pm
I've go a how on youtube as well to setup the Maya44. msg me if you'd like the link.
geposted Wed 21 Apr 10 @ 6:37 pm
