hi all.. just started using this software (v6) and would like to know how i can use my headphones as well as speakers..? ive tryed to but can only seem to get sound to come out of one ..ie headphones or speakers.. not both.. ive mixed on real decks for years all i want to do is have the track playing throu my speakers and the track waiting to be playing thou my headphones so i can get it ready to mix in.. help please..im a complete noob...!
geposted Thu 04 Feb 10 @ 9:16 am
In Order to use the headphone previewing mode with Virtual DJ, your soundcard need to be multi-channel ( referred as 4.1 or 5.1 for standard computer soundcards) and have the appropriate connections (often identified as FRONT , REAR, and Center/sub)
a) Check that your sound card’s speaker mode is set to 4-channel or 5.1-channel, using the sound card's own control panel ( ** Recommended) or at worst through Windows SOUND AND AUDIO PROPERTIES ( Volume tab > Speakers settings)
b) Connect your headphones to the rear speakers connector on your sound card (black connector on most sound cards).
c) When you run VirtualDJ,
- Input : None
- Output(s): Headphone > Master Chan3/4 / headphone Chan1/2
-Soundcard: 4.1 card > You soundcard card name
** Some integrated sound cards use a system allowing the usage of card's connectors for various fonctionalities, which may require some configuration by the user. Please consult the card's documentation for more details about theses possibilities
All this being said, I would recommend a soundcard that is made for DJ applications (that has 4 channel ouputs), such as these examples:
http://www.djstore.com/group/soundcards.htm
- Input : None
geposted Thu 04 Feb 10 @ 11:09 am
