Hey all. I just wanted to know why is it when I want to save a virtual folder in order that I play the songs in, it never goes in order that I put them in. Is there a shisetting that I need to adjust ie I put in sean paul 1st and then beenie after. When I do this, beenie seems to end up ist and then sean paul 2nd. please help
geposted Thu 04 Feb 10 @ 2:09 pm
If you right click on the virtual folder you'll see an Up and down option which will place the folder in any position you want within that tree, you can't make subfolders, this option is only available in the regular folders.
Good Luck
Joey......
Good Luck
Joey......
geposted Thu 04 Feb 10 @ 5:24 pm
Ok, thanx for the help. I will give that a try :)
geposted Fri 05 Feb 10 @ 9:23 pm
