I am using the M-Audio uno midi interface cable hooked up to the computer and mixer with the driver installed and everything. i'm not totally sure but i think my problem is that VDJ is not even detecting my mixer. I know its not my computer, mixer or cable because it all worked fine with the traktor 3 demo the mixer came with. I would really like to know what the problem is and what would need to be done to fix it. Thanks.
geposted Fri 05 Feb 10 @ 12:50 am
Do you have a DDM4000 mapper in your VDJ?
geposted Fri 05 Feb 10 @ 6:03 am
no i dont. i've tired to download it but the site wont let me,i guess im not a registered user.
geposted Fri 05 Feb 10 @ 8:47 am
as a registered Pro user you would have access to any mapper that comes out.. now or in the future..
geposted Fri 05 Feb 10 @ 9:49 am
ok, so bassically there's no other fix other than to become a registered user?
geposted Fri 05 Feb 10 @ 12:52 pm
Thanks a lot I really appreciate it. so now VDJ should be able to detect the mixer now?
geposted Sat 06 Feb 10 @ 12:50 am
the controls won't map right. channel ones high controls the high and the volume fader and channel twos volume fader controls channel ones volume fader. i cant figure out why this is, i am mapping them right but they will not control what i assigned them to. why is this?
geposted Sat 06 Feb 10 @ 2:28 am
I am a witness. Lots of features will not work the way they are designed to work when you don't have a legal copy of the program. I used 'crack' for about a year. I had so many things that I could not do with the program that I was supposed to be able to do. Finally, I gave in and bought the program. I didn't change my setup, only went from the cracked version to the legal version. Made the exact same adjustments on the legal copy that I had in the cracked version, and everything started working EXACTLY as it was supposed to.
geposted Sat 06 Feb 10 @ 10:33 am
Another post deleted? At least say why?
I'm just trying to help! That was my mapper
geposted Sat 06 Feb 10 @ 2:00 pm
Did you not read the post that was made above? It explains why.
geposted Sat 06 Feb 10 @ 5:16 pm
alright well thanks everyone I might just end up going with Traktor anyways but it was worth the try.
geposted Sat 06 Feb 10 @ 9:57 pm
@ Support Staff
Maybe that's my problem.
geposted Sun 07 Feb 10 @ 1:57 pm
