I am trying to switch TO video from audio...Here's my problem...
Coming out of Laptop
VGA - VGA works perfect....However VGA - composite or VGA to S-Vid does not work...cannot get a usuable picture....No matter what i do with screen resolution...
What are people using to get the signal from VGA to the other formats....My Laptop only has VGA out.
Most of the clubs i dj in are going to be composite.....
geposted Fri 05 Feb 10 @ 10:42 am
geposted Fri 05 Feb 10 @ 10:55 am
I haven't yet....Trying to see what dj's use that are dj'ing video to come out of laptop.
geposted Fri 05 Feb 10 @ 11:01 am
what are using currently to convert from vga to s-video or composite?
geposted Fri 05 Feb 10 @ 12:39 pm
I've tried various adapters.....vga to s vid and a vga to composite....I was at an IT friends house and he was trying everything and anytging patch cords and nothing would give us a even somewhat usuable pic.....laptop only has vga out..
geposted Fri 05 Feb 10 @ 12:59 pm
theirs no such thing as a "patch cord" that will convert VGA to composite.. you need a converter..
(as was shown above by TDBennet)
I havent used one for years, so I cant really recommend a current product..
I do know that their are lots of options and the prices have really come down..
only advice I can give.. make sure you get one thats usable for long distances..
geposted Fri 05 Feb 10 @ 1:19 pm
you need the converters for scan conversion; different scan rates from vga to composite.
the ones I listed above are kind of consumer grade. If you need more professional, which equals more money,
you can go with Kramer or Altinex. There are other manufacturers as well, I'm familiar with Kramer and Altinex and they've always worked well. BlackBox used to make some cool little converters but I just don't do huge video system installs anymore so I'm not up-to-date on the latest and greatest.
good luck,
T
good luck,
T
geposted Fri 05 Feb 10 @ 1:39 pm
I appreciate every ones advice on this....I guess i need a converter...No problem, IF that will get the job done. The clubs i am at all have a component plug that is acessable to me....with the below work?
http://www.newegg.com/Product/Product.aspx?Item=N82E16815158142
geposted Fri 05 Feb 10 @ 2:33 pm
I use this on one of my machines
http://www.buy.com/prod/grandtec-pc-to-video-ez-vga-grandtec-pc-to-video-ez-vga-10486615/q/loc/101/10391548.html
geposted Fri 05 Feb 10 @ 5:12 pm
Yup!
a little expensive but sometimes you DO get what you pay for.. also keep in mind.. these things don't really "wear out" so it can possible last you for ten years.
the only thing i dont like about it, is it doesnt have a VGA pass-thru (usefull for expansion)
geposted Fri 05 Feb 10 @ 5:46 pm
I appreciate everybody's help...Looks like through your links i'm gonna get what i need.
Many thanks and i will post the results when i go VIDEO!!!!!
geposted Fri 05 Feb 10 @ 7:33 pm
I have two of these units (one vga to component and one s-video to component and they make virtually any converter you need...great units http://www.atlona.com/Audio-Video-Converters-p-1-c-306.html
geposted Sat 06 Feb 10 @ 1:25 am
I don't mind spending the money on one of these, I just want one that will work...I'm seeing a WIDE variety of prices on these links...It looks like 2 of the 3 places i spin at are using Component/RCA.....So thats what i will be plugging into...VGA to Component...How much Difference in quality of picture is there between these $39 units and $250 units? If Component only does a certain resolution than it should be the same on all units correct?
geposted Sat 06 Feb 10 @ 9:49 am
the more expensive units usually have better controls for configuration. you can adjust the scan rate very well with some of the more expensive units. if you work alot of different venues then you may need some flexibility. try out some of the units you can pick up at local retailers and see how they work. if you can't find a decent comsumer grade unit then go to the pro units.
geposted Sat 06 Feb 10 @ 7:06 pm
Thanks TD, I ordered the 1 from New Egg...So I'll give it a try and see how it goes....If i have to step up then i will.
geposted Sun 07 Feb 10 @ 10:31 am
I've been using one of these for over two years now;
http://www.maplin.co.uk/Module.aspx?ModuleNo=223833
Maplins = Radio Shack in the USA.
Plugs into the VGA output, has a VGA pass thru, S-Video and Composite Video outputs
geposted Sun 07 Feb 10 @ 11:19 am
I ordered the one from new egg....no setup required, just plugged everything up and of course activated screen 2 in windows and it worked perfect....plugged str8 into my projector via vga out to component in and getting a very good to above average pic... Thanks everyone for your help...
geposted Wed 10 Feb 10 @ 9:10 am
glad you're satisfied. thanks for posting your results.
geposted Wed 10 Feb 10 @ 10:40 am
