As title says, for recently added files on mac version, even after playing file, bitrate field shows empty. I searched forum and could not find any solution. Does anybod how I get have them displayed ?
iTunes and Viewer show bitrates on all files.
Patrick
Patrick
geposted Fri 05 Feb 10 @ 4:07 pm
Anybody has a clue from either users or VDJ team ?
geposted Mon 10 May 10 @ 7:16 pm
Is the "Read ID Tags" enabled in your config menu?
geposted Mon 10 May 10 @ 8:45 pm
This is a known bug and has been reported both here and on the experienced users forum. Hopefully the dev team will address this in the next big update to the Mac version. One workaround (if you have bootcamp or parallels) is to change the file locations in the DB, scan them in windows then convert back to Mac. That then stores the bitrates correctly. Keith
geposted Tue 11 May 10 @ 2:27 am
Thanks for this update Keith, I thought about the Windows workaround and will do that for now.
geposted Fri 14 May 10 @ 2:39 am
