hey i was thinking about purchasing a dj tech i-mix reload. But i discovered that they don't have a headphone jack despite having a soundcard.
So i guess my questions are; do you plug your headphones into your computer to cue up your next track when using this controller? or do you have to do something else?
Also would you recommend getting this controller? if not, what controller would you recommend insted? i have looked at the hercules RMX, but i want touch sensitive jog wheels, hence why i want to use the I-mix reload.
Thanks for even reading this, sorry if any of these questions are stupid.
geposted Fri 05 Feb 10 @ 8:06 pm
If you like the DJ-Tech Reload then get the Reload MK2 ... it has the soundcard built-in and has the headphone jack on the front.
geposted Sat 06 Feb 10 @ 1:28 am
