whenever i run vdj it says my database is corrupt. ive lost all my bmp and cues! any help???
derek
derek
geposted Mon 16 May 05 @ 1:45 am
i had the same problem, rename the database file in vdj system folder or move it (dont del sum1 might have a betta solution) then start vdj up and scan again shudnt display database is corrupt =D
geposted Mon 16 May 05 @ 12:39 pm
Do you bave a backup of your VirtualDJdatabase.xml file ?
If yes copy it to your VirtualDJ root directory.
Tell us.
Tell us.
geposted Mon 16 May 05 @ 3:28 pm
If not, ...cry !
Thats life ..
Thats life ..
geposted Mon 16 May 05 @ 4:17 pm
We all doneddd dat before.....
I copy the data base and playlist file once a week.
geposted Mon 16 May 05 @ 4:23 pm
i dont have it saved no. i can live with scanning it all again but it doesnt seem to be saving the database when i scan any new songs so im a bit worried - it just says internal database is corrupt eveytime i start it up. ill scan it overnight tonight and see how it turns out.
geposted Mon 16 May 05 @ 7:58 pm
Please, can you tell me this :
1. what version are you running?
2. Does the database work, even if you do get an error message?
geposted Mon 16 May 05 @ 8:01 pm
be sure to wait patiently when you close VDJ. That is when the database is updated. If vdj closes due to error, or you simply shut down the computer, your database will possible be corrupted.
geposted Mon 16 May 05 @ 11:32 pm
If you still get the database corrupt message, you should get to modify the "internal database.xml" file to add the missing closing tags that are needed in the end of the file. Or else cut the file elswhere from your VirtualDJ root folder and see if virtualDJ creates a completely new database.
geposted Mon 16 May 05 @ 11:42 pm
