ok ive rounded up as many midi controllers as i can for about 150 squid, (vinyl djing would be nice but its just to dear)
ICUE Dj http://www.maplin.co.uk/Module.aspx?ModuleNo=221995 (£99)
Hercules E2 http://www.maplin.co.uk/Module.aspx?ModuleNo=226574 (£99)
Ion Discover DJ http://www.maplin.co.uk/Module.aspx?ModuleNo=348287 (£99)
Numark Total control http://www.htfr.com/more-info/MR222706 (£155.99)
Behringer BCD3000 (doubles as sound card) http://www.htfr.com/more-info/MR226431 (£149)
Behringer B,C,D, 2000 (doubles as a sound card) http://www.htfr.com/more-info/MR170519 (£159)
if anyone can review any of these im mucho liking the Behringer BCD 3000!! whats the diffrence between the 2000 vs 3000???
Any help much apreciated!
geposted Sat 06 Feb 10 @ 5:15 pm
check the forums & archives as many of these units are 3-4 yrs old & already been covered in detail
The prices should also have been reduced
consider that some controllers require an external soundcard to enable you to mix & monitor or add a mic input, a good quality soundcard will also inflate the cost.
I recently commented on the ion discover in Dj smackdaddys thread.
I have owned bcd2000, i cue & total control so i speak from experience.
I would avoid the bcd 2000 as i had many audio issues with it on a clean healthy pc
Total control & i cue are both Numark brands , the i cue is a simplified version of total control.
I cue has no midi mapping, or mods that i'm aware of. Its activated by the limited range of software which supports it.
I have a video link of the i cue in my profile.
Total control has midi mapping & more features, functions & shortcuts so you barely need to use the mouse.
The i cues jog wheel is more sensitive than total control for some strange reason.
Regardless........All of the above are unsuitable for serious accurate scratching,cutting & cueing,but are fine when performing other tasks.
If possiible try & audition the product.
vestax recently launched spin & typhoon controllers which have built in audio & mic input which may also be in your range. so be patient & try & predict where you will be in the future & get the best controller to suit as many controllers have limitations & a short shelf life.
geposted Sat 06 Feb 10 @ 7:24 pm
