Hey guys I need some help in regards to VIDEO FORMAT I want your on what video format to use. I am using Any video converter which gives me lot choices, including resolution.
Q. What is works better with VDJ - what format? also format that help with the video freezin issue.
Q. What resolution would be ok without compromising to much quality and saving Hard drive space
At the moment Am using mpeg2 but audio I am not impress with and not getting support for video tag.
Thanks.. Dj Memo
Thanks.. Dj Memo
geposted Tue 09 Feb 10 @ 5:18 pm
i use mpg2 and don't have any problems with it but that can also be down to the lappy i'm using,iton dead lucky never had any issues with it.
many of the guys are going over to mp4 as i believe that has tagging capabilities.
geposted Tue 09 Feb 10 @ 6:31 pm
Hi Tayla thanks for the info. What resolution are you using??
geposted Tue 09 Feb 10 @ 6:41 pm
My advice is Dont Convert video file and Dont Resize them either.
geposted Wed 10 Feb 10 @ 9:20 am
But some videos are too big take too much space. It had to be a better way to do it?
geposted Thu 11 Feb 10 @ 2:10 am
