Using a Acer Travelmate 4200 notebook...video card is Intel Graphics Media Accelerator 950 (i know low end)...Video's plays fine and i never use more than 80% - 85% CPU...And that is on initial first 3 sec of loading video when another is playing and then it drops to about 40% CPU usage...takes maybe 6-8 sec to load entire video.
Question 1
When trying to use the logo plugin ...when i try to load .png logo it gives me a cannot load error message....Is that because my video card is low end? and won't allow it? I can't figure out why it won't load...logo is 90kb...it doesn't give you a "why it won't load"
Question 2
Everything i have read/heard says use video accelerator in config menu...but when i do...audio for a video still plays but video no longer does...Once again is that because of video card being low end?
Question 3
If i get a hi-end video card that runs off of usb...will that solve any problems from above?
What difference can i expect using a hi-end video card vs the one i have...when my pic out is fine and shows good on video screen...and no glitches
Question 1
Question 2
Question 3
geposted Wed 10 Feb 10 @ 12:34 pm
@ qestion 1
Try to activate show logo effect first, then load logo file.
Regards Tjeck
Regards Tjeck
geposted Wed 10 Feb 10 @ 3:22 pm
I tried it that way and it doesn't work...i have made it work on my desktop, so i imagine that my video card in my laptop is just not able to do any of the effects...it can only run straight video.
geposted Wed 10 Feb 10 @ 5:07 pm
I thought show logo only works with jpgs? If I am wrong somebody let me know what other file formats are allowed.
geposted Thu 11 Feb 10 @ 5:23 am
do any of your other video effects work? if not you will need to install directx 9 and c++ here is the link for the latest dx9 5/2/10 and c++ can be found on the same site just put a search in for it...
http://www.microsoft.com/downloads/details.aspx?familyid=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displaylang=en
geposted Thu 11 Feb 10 @ 7:05 am
@nutnbutnet
PNG. file format ios also allowed. I use it because of transparent back gound possibility.
Regards Tjeck
Regards Tjeck
geposted Thu 11 Feb 10 @ 7:42 am
Tayla thanks for the link...i will try this...however since my vid card is old and a low end version...i went ahead and purchased a "gamer" laptop from tigerdirect....This should do the job.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5250511&CatId=4948
geposted Thu 11 Feb 10 @ 8:46 am
you will still need to install both of the above to get video effects to work, hope you enjoy the new toy... lol
geposted Thu 11 Feb 10 @ 10:50 am
+1
geposted Thu 11 Feb 10 @ 2:07 pm
I installed on my "older" laptop and it still didnt do the effects.....but i have saved the files and will install on the new on when i gets here...thanks.
geposted Thu 11 Feb 10 @ 2:37 pm
