Hey, i have the hercules steel.
at the top left of the console there is a little button that ses "Apply Ctrl. On" next to it and on the otherside there are 3 lights laid out like this :
Light 1 : Deck A
Light 2 : Select
Light 3 : Deck B
when i press the "Apply Ctrl. On" button the light changes from one to the other. when the "select" light is on, all of the effect buttons light up and 1 or two of them flash a bit.
does anyone know what this actually does???
ive read the manual and cant make sense of it.
any help would be great. thanks
Light 1 : Deck A
Light 2 : Select
Light 3 : Deck B
geposted Thu 11 Feb 10 @ 1:35 pm
Pressing APPLY CTRL simply indicate which deck the 2 CONTROL knobs are being used for.
In SELECT mode, the buttons that flash are one currently being used.
If you are in this mode and press a button , you will then be switched to either DECK A or DECK B (according to which side you made the selection) and the 2 CONTROL knobs will be available to modify the settings of the function assigned to this button ( FX parameters, sample volume, loop length, etc).
geposted Thu 11 Feb 10 @ 1:51 pm
eh... this seems pretty pointless as it just selects which deck the knobs are used for as soon as you press the effect :S
geposted Thu 11 Feb 10 @ 2:03 pm
You don't have to tell me, but it seems that's the way VDJ wanted to use these controls....
geposted Fri 12 Feb 10 @ 12:49 pm
