People please remember to turn OFF the internet connection everytime you open the Virtual DJ program when just "practicing"or playing around, in configuration setup in the Internet tab* within Virtual DJ (check the "Disable Musicgroups for this session only" box), that will help with the MusicGroups songs that get suggested to DJ's while they are actually doing a real gig, and not something that doesn't flow with the mix. After you are done practicing and/or come up a playlist you want to keep to play in the future, save it and then close Virtual DJ then reopen the program but this time leaving the internet tab alone* (it automatically is ON unless disabled every time you open Virtual DJ), play your saved playlist and this process will have you contributing that playlist mix to any musicgroups you might be a feeder for. This also helps when you are editing your tracks/playlists if you have your only music group, so you don't have to delete any unwanted songs that you post on your "recently played" list should you show that to other Virtual DJ community members.
*You must have an internet connection. Party on!
geposted Fri 12 Feb 10 @ 12:53 pm
