I saw this somewhere on the forum, but can’t find it…
I have plugged in 2 pioneer CDJ’s. The problem is that the players/Decks on Virtual DJ and those on my CDJ’s are crossed (left side of VD controls the right side of CDJ-1 and right of VD controls the left side of CDJ-2.
I read that there is a command or key that we can use to switch the sides of the players. Can anybody tell me how it’s gone.
Thanks !
Thanks !
geposted Fri 12 Feb 10 @ 2:48 pm
Which Pioneer CDJ's? 400, 800, 900, 1000 or 2000? Are you using timecode or MIDI/HID-mode?
geposted Sat 13 Feb 10 @ 6:50 am
All MIDI / HID tabletop CD controllers have the EJECT button coded to invert_controllers. So just press the Eject to swap them.
Also you can easily tell if the need swapped by looking at the display of the units (if the display functions) and you will see the Track Number displaying which deck that controller is assigned to.
geposted Sat 13 Feb 10 @ 7:25 am
