Wassup?
I currently use a denon hc4500 and denon dn x500 mixer, with a numark tt200 for scratching.
My question is, if i picked up a soundcard, another table and used my time coded vinyl, would i be able to hook up two time coded vinyls and still use my hc4500 at the same time? (sound card set to whatever soundcard i choose to buy, i know that i can still control vdj with denon hc4500 even when its not set as the soundcard).
Basically i wana have timecodes for mixing/scratching and have my hc4500 for controlling effects, cue points and all that good stuff and as a back up. NOTE: I AM NOT SENDING ANY OUTPUT SIGNALS FROM HC4500 TO MIXER, JUST USING IT TO CONTROL SOFTWARE
thx in advance
peace!!!
thx in advance
peace!!!
geposted Sat 13 Feb 10 @ 11:33 pm
apparently you can, im currently looking to do a similar setup and i know peeps on there have had setups similar too. just not sure how to set it up yet.
geposted Wed 17 Feb 10 @ 3:41 pm
