Is is possible say If I backed up my files and then restored them in another computer, would all my cue points be saved as it has taken me ages to cue everything just how I want it. Thanx in advance for any help.
geposted Sun 14 Feb 10 @ 12:21 pm
speng all your cue points data to files ect are saved in your .xml file within your virtual dj folder in my documents.save this folder on new computer then redownload vdj on new computer and vdj will pick it up im sure
geposted Sun 14 Feb 10 @ 4:30 pm
Only IF you keep the same file structure on both systems.
geposted Sun 14 Feb 10 @ 5:16 pm
Ok great. I will try this and see if it works. If it does as you say, I will be over the moon ?
geposted Mon 15 Feb 10 @ 5:02 pm
