I have a question , I know jog wheels have to scratch function , and pitch funtion, but can you use the jogs wheels like turntables and search thru songs or line up beat spikes, if so how can you change the sensitivity of the wheels.
geposted Mon 15 Feb 10 @ 12:14 pm
in the rmx config there is a jog wheel sensitivy up to deactivate, there you should be able to adjust according to your likng..fyi its only like a 3 level adjustment tho!.
geposted Mon 15 Feb 10 @ 3:55 pm
just to add my 2 cents.. as much as ive tried scratching with jogwheels, its damn hard. your gonna need a shed load of practice and a whole load of patience..
geposted Wed 17 Feb 10 @ 3:37 pm
Whats a good sensitivity I had mine up 200 sommm:::
Lowered it and it sound it better ..
Any Ideas
Any Ideas
geposted Fri 21 May 10 @ 10:03 pm
