Where do I enter the serial number for VDJ?
I have searched these forums and Googled this matter but nothing useful has been forthcoming.
Thanks
John
Thanks
John
geposted Mon 15 Feb 10 @ 8:38 pm
Well, considering you have Pro User status it seams you already figured it out ;-) Welcome to the jungle...
geposted Mon 15 Feb 10 @ 9:01 pm
Somehow that was the kind of response I expected.
Anybody else able to help please?
geposted Mon 15 Feb 10 @ 9:04 pm
What would also be useful is finding the correct ASIO driver. I seem to have acquired several different versions on my laptop and don't know which one is correct for my machine. I use a Denon 4500 controller on a Sony Vaio laptop which is running Vista (but hopefully not for much longer - Windows 7 upgrade on the way).
Thanks
John
Thanks
John
geposted Mon 15 Feb 10 @ 9:07 pm
One would hope you are using the ASIO driver provided by Denon on their web site:
http://www.denondj.com/firmware.aspx?ProductId=81
geposted Tue 16 Feb 10 @ 6:15 am
Terrys response was valid as you didn't quantify what you are trying to do.
If you are trying to register your serial number on here, then you do it in "Modify my profile" which you have obviously already done since you are registered.
If you are trying to enter in the software to upgrade a trial you can't. You need to download the licensed version from your download centre, which will then prompt you for your serial when you run it.
geposted Tue 16 Feb 10 @ 6:42 am
Thanks SBDJ.
Please excuse me, but it has been a very frustrating few weeks.
I already installed VDJ on the laptop which turned out to be faulty. Please don't tell me that the licence is only valid for one machine.
I just have a small fear now that the latest laptop may need to be returned. Hopefully I can re-install on each machine for now, until I find one which actually works.
Thanks again.
John
Thanks again.
John
geposted Tue 16 Feb 10 @ 6:49 am
Your install files and serial number is always located in your download center by your name above.
Driver and firmware updates are available on the Denon website once you register your gear with them.
geposted Tue 16 Feb 10 @ 7:49 am
I have the denon 4500 and a sony vaio laptop with vista, once i hook up the usb cable to my laptop it crashes, the screen turns blue it displays that the computer is protecting it self from damage and to check out the audio driver, what can i do to solve this
thanks
thanks
geposted Sat 20 Mar 10 @ 11:18 am
your first step would be to start a new thread, instead of adding to an old one..
thanx :-)
geposted Sat 20 Mar 10 @ 2:40 pm
