will the RMX/steel rackmounts work in conjusction with the mp3e2 controller?
geposted Wed 17 Feb 10 @ 12:01 pm
Can you be a bit more precise ?
geposted Wed 17 Feb 10 @ 2:04 pm
not sure how more specific i can be really. but here go's
if i take the RMX rack mount brackets will they screw to the sides of my mp3e2 controller and allow me to screw that into my rack?
by rack mount brackets i mean those right angled thingys that have holes in em to let you put your herc in your rack. by screw i mean to fix not to molest or do over. and by rack i mean dj not titties..lol. though screwing titties does sound a better option. lol
geposted Wed 17 Feb 10 @ 2:48 pm
No, it won't.
The chassis size of the RMX and Steel are the same (as each other), and rack kits can be used with them.
The chassis size of the e2 and the forthcoming mp4 are also the same (as each other), but not the same as the Steel and RMX, and would not work with the rack kits.
geposted Fri 19 Feb 10 @ 12:54 pm
thank you steve. looks like the old radiator brackets are coming out and getting butchered..
geposted Fri 19 Feb 10 @ 12:59 pm
he said screwing titties... HA!
geposted Fri 19 Feb 10 @ 1:19 pm
Just take your controller to an engineer and tell him what you want an he'll sort it for you, it's a very easy job. Just be thankful you live in the UK if you were in India or an arabian country then this would be a real issue.
geposted Fri 19 Feb 10 @ 2:39 pm
hhhmmm engineer you say???
my brother in law is an engineer. mind you ive thought of a preferred method to the rack mount, i want my controller kind of angled up behind my mixer.
so i can access it easily.
geposted Fri 19 Feb 10 @ 3:34 pm
