Looking to get a new laptop. Can someone with an intel i5 or i7 comment on their experience with these processors.
Thanks.
Thanks.
geposted Wed 17 Feb 10 @ 7:21 pm
The I7 processor is great, its a big step in processing power and with 7 cores it would help vdj run much lower latencys
AO as far as processors go id get an I7 over anything else.
DJ JAMM
DJ JAMM
geposted Wed 17 Feb 10 @ 8:42 pm
Quote :
It's 4 cores for a TRUE i7 processor and only 2 cores for the i7 mobile.
i7 - http://www.intel.com/products/processor/corei7/specifications.htm
i7 mobile - http://www.intel.com/products/processor/corei7/mobile/specifications.htm
i5 - only 2 cores - http://www.intel.com/products/processor/corei5/specifications.htm
i5 mobile - also 2 cores - http://www.intel.com/products/processor/corei5/specifications.htm
But yes, the i7 is a better spec'd processor than the i5.
geposted Wed 17 Feb 10 @ 9:20 pm
This is the system I was looking at.
Windows 7 Home Premium 64-bit
CPU Type Intel Core i7-720QM(1.60GHz) Quad
4GB DDR3, DDR3 1066
Video Memory 1GB GDDR3
Intel HM55
GPU/VPU NVIDIA GeForce GT 330M
Or should I go for a faster Dual Core CPU like the Intel Core 2 Duo T9600 2.8GHz?
Is a faster Core 2 Duo better than a slower i7?
Thanks.
4GB DDR3, DDR3 1066
Intel HM55
Thanks.
geposted Thu 18 Feb 10 @ 12:25 am
No, a faster core 2 duo is not faster than a "slower" 1.60 GHZ 720QM i7. On my windows experience index I get a 6.9 for my laptop running an i7 720QM CPU on my other PC with a X9100 core 2 extreme 3.06 GHZ cpu I get a 6.6 and as far as I know the X9100 is the fastest mobile 2 core CPU, I can't go any faster on that laptop.
I am at a 6.9 with 720qm i7 CPU and I can still swap out the CPU and upgrade for higher models of i7 like a 820QM or a top of the line 920XM (Drooling).
geposted Thu 18 Feb 10 @ 1:44 am
hi Maragar8... what do you think ov this set up. just been offered one and am wondering if it is suitable for VDJ.
# Processor - Intel Pentium T3400 / 2.16 GHz ( Dual-Core )
# RAM - 3 GB DDR2 SDRAM - 800 MHz ( 1 x 1 GB + 1 x 2 GB )
# Hard Drive - 320 GB - Serial ATA-150 - 5400 rpm
# Operating System - Microsoft Windows Vista Home Premium
# Screen - 15.6' TFT 1366 x 768 ( WXGA )
# Optical Drive - DVD±RW (+R double layer) / DVD-RAM
# Graphics - Intel GMA X4500
would you rate this system??
xxx
xxx
geposted Wed 03 Mar 10 @ 7:10 am
