If I am using a skin that was designed at 5.2 level, what will happen if I use it with the current version?
What will I notice different?
geposted Wed 17 Feb 10 @ 10:27 pm
I am using Mixlab with ver 6.05
No problems here.
No problems here.
geposted Thu 18 Feb 10 @ 10:23 am
Most skins designed for VirtualDJ v5 should work OK with VirtualDJ v6.
geposted Thu 18 Feb 10 @ 1:05 pm
Thank you for the feedback. Just wanted to be sure. I had noticed on skin creator there was a option to convert to v6+, so I thought there may be a lack of option.
geposted Thu 18 Feb 10 @ 7:30 pm
That will attempt to convert the old VirtualDJ v5 actions to the new VDJscript used by v6.
However, v5 skins can be used without any modification necessary.
geposted Fri 19 Feb 10 @ 12:20 pm
