VDJ community,
Does any one know of a program or a way to check if i have duplicate entries in my music library?
it seems as much i try to eliminate them, some are always there that i miss
thanks.
thanks.
geposted Sat 20 Feb 10 @ 11:43 am
Try this
http://www.easyduplicatefinder.com/
Regards Tjeck
Regards Tjeck
geposted Sat 20 Feb 10 @ 12:23 pm
Just purchased it. Cleaned out about 6 gigs of music and vids. Thanks!
geposted Sat 20 Feb 10 @ 11:58 pm
Purchased it?? It says free on the site. Hmm?
geposted Sun 21 Feb 10 @ 12:56 am
Well,, it's a free demo of sorts. it will delete 10 duplicates at a time. if you don't have many, then that's fine...but I had quite a few to take care of so I bought the full version! Unless I got swindled.....:(
geposted Sun 21 Feb 10 @ 1:01 am
Tjeck1972 wrote :
Nice find Tject,
Cheers!!!
geposted Sun 21 Feb 10 @ 5:09 am
Thanks guys
geposted Sun 21 Feb 10 @ 9:48 am
there is a free software on cnet.com called doublekiller. You can specify what to look at ie name of file, size if file etc then it allows you to desinate which of the duplicated files to delete. Works great and the price is excellent.
geposted Sun 21 Feb 10 @ 11:15 am
