there basically about the same price, and reason im stuck on which one to buy is because pioneer has been the industry standard and i know cdj 200 aren't going to brake on me, and the ndx 800 aren't even out yet so im not to sure what to do.
but ndx 800 by numark has loads of more features, its a midi controller, and has a usb plug, plus more effects
what do you think?
(and i would buy the cdj 400 but sadly don't have $625 x2 = 1250 to spend on decks, instead of $800)
if you wanna read... *quickly pulled of numark and pioneer website
NDX 800
CD/MP3/USB player with USB-MIDI computer interface
Play from CDs, MP3 CDs, USB flash drives, and control software
Beat-synced DSP effects with wet-dry fader: chop, echo, filter, flanger, pan, phaser
Smooth, fast, reliable, slot-loading drive
Large, seven-inch, touch-sensitive illuminated platter with touch-sensitivity adjustment
Control MIDI software with no timecode needed via USB
Adjustable start and stop time for vinyl-like deck performance
Automatic BPM analyzer and Tap tempo for manual BPM entry
Adjust pitch ±6, 12, 25, and 100%, in half steps (semitones), or bend with pitch buttons
Key Lock holds pitch while you independently manipulate its BPM
Seamless looping, sampling, and easily accessible hot cues
Keep time moving forward while you cut or reverse the track using Bleep/Reverse
Single-track, continuous, shuffle, and programmable playback
Fader Start plays the cued track when you move the crossfader (requires compatible mixer)
Large, backlit display for BPM, CD/MP3 text tags, and folder navigation
Outputs: stereo RCA, digital S/PDIF
CDJ 200
Hot Loop Yes
Quick Start Yes
Auto Beat Loop / Emergency Yes
Beat / Loop Cutter Yes
Real Time Seamless Loop Yes
Loop AdjustOut Adjust
Reloop Yes
Digital Jog BreakJet, Zip & Wah
Cue / Loop Memory Yes
Shock-Proof Yes
Jog Dial size 100,0 mm
Jog Dial type Jog Dial
Jog Modes CDJ mode
Pitch Bend Yes
Fader Start / Back Cue start Yes
Relay Play Yes
Frame Search 1/75 Sec
Master Tempo Yes
Tempo Control steps0.02% at +/-6%, 0.05 at +/- 10% & 16%
Tempo Control Ranges (CD)+/- 6%, +/- 10%, +/- 16%
BPM Counter Yes
Front loading Slot-In CD Yes
Auto Cue Yes
Manual Cue Yes
Real Time Cue Yes
Cue point sampler Yes
Display Yes
Playing AddressYesMedia Loading Type Slot
Headphone Output Yes
Anti Vibration Yes
Analogue Output Yes
Digital Output Yes
Type of Discs12 & 8cm CDs
Disc FormatCD, CD-R, CD-RW, MP3 CD
MP3MPEG-1 32Kbps - 320 Kbps / MPEG-2 16 Kbps - 160 Kbps
MP3 Folder Search Yes
Included AccessoriesPower cord, manual, stereo phono cable, Control Cord, Forced Eject Pin
what do you think?
NDX 800
CDJ 200
Hot Loop Yes
Quick Start Yes
Reloop Yes
Shock-Proof Yes
Jog Modes CDJ mode
Pitch Bend Yes
Relay Play Yes
Master Tempo Yes
BPM Counter Yes
Auto Cue Yes
Manual Cue Yes
Real Time Cue Yes
Display Yes
Anti Vibration Yes
Analogue Output Yes
Digital Output Yes
geposted Sun 21 Feb 10 @ 11:39 am
