OK. I have been searching everywhere and still haven\'t gotten a 100% confirmation:
If I have VDJ but only 1 turntable, can I use a time code vinyl to control both the virtual decks in VDJ? And if so, can I use a USB external audio interface with 1 stereo input/1 stereo output (input from turntable (Stanton T80 has line level) and output to mixer), for example, the Behringer UCA 222 (with ASIO)?
Thanks
Thanks
geposted Sun 21 Feb 10 @ 1:09 pm
I believe u can, but not 100% sure. I'll try it tonight. And I believe you can use that soundcard
geposted Fri 05 Mar 10 @ 11:12 pm
You can but you have to click back and forth between decks.
geposted Sat 06 Mar 10 @ 11:01 am
The answer is yes. The timecode will control whichever deck is active (it defaults to the deck that is playing unless you click to the other active deck by click ont the deck number.) I have used this setup before when using Stanton SCS.3d's to control the decks but needed vinyl to scratch or do pullbacks.
geposted Mon 15 Mar 10 @ 2:45 pm
