I was DJ'ing at a house party last night and after hours playing the sound suddenly cut off. VDJ did not crash but no sound played. i closed the program and re-started and there was no further problems. this is the 2nd time this has happened.
i have the latest VDJ and brand new macbook pro
geposted Sun 21 Feb 10 @ 1:23 pm
Which Version of VDJ are you using exactely ? (Pro/Basic/LE/Home, v5.x or v6.x)
Greets, Heiko
Greets, Heiko
geposted Sun 21 Feb 10 @ 1:25 pm
6.0.5 for Mac
geposted Sun 21 Feb 10 @ 2:10 pm
Is it the trial you're using? (guessing this as you don't have a pro licence)
Last night I had the sound drop out on me three times for 4 or 5 seconds. It's the first time I've used the mac version live (Snow leopard and DN-HC4500 asio)
Testing it at home again this morning and no problems at all.
Could have been the soundweb at the club going wonky again, not sure ......
geposted Sun 21 Feb 10 @ 2:23 pm
Pro version bought last month
geposted Sun 21 Feb 10 @ 2:33 pm
Make sure you add your serial number to your profile. It will get you free updates for life and assist when submitting support tickets.
Cheers,
Roy
Cheers,
Roy
geposted Mon 22 Feb 10 @ 3:05 pm
were you using a external mixer?..I dj'd a house party once with a old pyle 2 channel mixer it died twice... I had to turn it off, on, jiggle stuff....pray... walla! came back on. Ive never had sound drop out from VDJ.
geposted Mon 22 Feb 10 @ 11:01 pm
yes i was using xone 22 mixer
geposted Tue 02 Mar 10 @ 1:19 pm
