I've been using my DJ Console MK2 for quite some time. Well recently, my CD drive on my laptop went down the tube. I brought it back to my local Apple Store and got it covered under the AppleCare. I backed everything up that I could before I sent it in just to be safe, I even backed up the entire Virtual DJ folder I had on my laptop. They say that they shouldn't have to wipe the harddrive or anything, its jut a DVD/CD drive replacement.
Well a week later, I get my laptop back. Well lo and behold, my harddrive is completely wiped out. Thankfully I took the extra step of backing everything up. I went to put Virtual DJ folder back into my Applications folder, and now I cannot get it to work. I figured, I'd just go ahead and reinstall it, but I cannot for the life of me find my original CD nor the serial key. I even have the original box for the MK2, and inside of it, I still have my receipts from GC, but NO CD anywhere.
I took a little break from doing gigs, but its about to start picking up again, and I NEED to get Virtual DJ back up and working. Any help or suggestions will be greatly appreciated!
geposted Sun 21 Feb 10 @ 4:08 pm
if you've registered before go to download centre, your own individual license will be there, failing that...
put a ticket into support, they keep records going back all the way to checking the animals into the ark, vdj pro by the way is a download.
geposted Sun 21 Feb 10 @ 8:12 pm
