I am very new to VDJ! As I accumulate new music after intially setting up VDJ, how do I scan my hard drive to add new music in my VDJ library/database?
geposted Sun 21 Feb 10 @ 4:12 pm
just right click on folder or drive you want to add and select add to search data base and scan for tags (use other options from drop down window if needed)
geposted Sun 21 Feb 10 @ 7:02 pm
just a tip from experience lol.update you tage filenames ect to the way you want before you add to library.
or if you want to change name ect do so within vdj ie file infos.
if you add to database then rename them outside vdj you whole folder will change and you will get old entries to clog up db.
as when you change them within vdj your xml file will hold you changed data
geposted Mon 22 Feb 10 @ 1:47 pm
