hello, a question for the community:
How to mix songs sung beginning? For example tik tok of kesha that is difficult to mix.
What do you advise?
What do you advise?
geposted Sun 21 Feb 10 @ 6:25 pm
Personally, I wouldn't try to beatmatch the original of Tik Tok to something that finishes with vocals. There's not much you can do to make vocals over vocals sound good. You could just let the vocals of the last song finish then start Tik Tok. That's not beatmatching but sounds good for songs that don't start with a beat.
Alternatively you could get a dance remix of Tik Tok which doesn't start with vocals. I found a couple of good electro remixes on NetSearch but you will need to buy VDJ to use that.
geposted Mon 01 Mar 10 @ 5:29 am
