Hi Guys,
Hope someone can help me,
I have managed to put together enough money and i would like to purchase virtual dj 6. I would like to just ask 2 questions:
- If i purchase version 6, how long would i be entitled to updates, bug fixes etc.
- Does VDJ6 work well with windows 7 from anyone who has used it with win7
Thank you for your response.
geposted Tue 23 Feb 10 @ 8:23 am
1- You have unlimited upgrade. Until they say so.. Since their beginning it is free (like 10 years, hope they let it free another 10 years ;)
2- I run Windows 7 32bits, everythings fine, run always as administrator.
geposted Tue 23 Feb 10 @ 8:44 am
I am running VDJ with Win7 Pro 64-bit with no issues. I have a quad core system with 4gb ram. Hopefully that helps you.
Good luck.
Good luck.
geposted Tue 23 Feb 10 @ 9:19 am
There are many benefits. The updates are free like Sp33D said. Plenty of skins, tools, samples. Man all types of things. It will pay for itself. I've bought it atleast 15+ times................................Get it?...............Ok.
I use vista, so no help there.
geposted Tue 23 Feb 10 @ 10:52 pm
Thanks guys appreciate the help.
geposted Wed 24 Feb 10 @ 1:54 am
