Ok, question tried to set the sensitivity in settings is there any other way to adjust jog wheels for nudging within songs that are playing on deck nudging meaning to get to certain point in songs or lining up spikes or peaks in songs, any help would be great
geposted Tue 23 Feb 10 @ 11:53 am
In VirtualDJ Pro you will get more finer control over the jogwheel sensitivity, and can independently set it for scratch, cue and bend. You can also change the button mappings if you wish to suit your own preferences.
Please try the v6.0.6 trial: https://virtualdj.com/download/trial.html
NOTE: You can upgrade from your Hercules DJ Console RMX version to Pro at a considerable discount by going to https://virtualdj.com/buy/ and entering your DJ Console RMX Console Edition serial number in the box provided.
geposted Tue 23 Feb 10 @ 12:03 pm
also on the RMX there is a "scratch button" on the top of the controller, in between the EQ knobs.. if you deselect it you should be able to nudge the song with out it scratching...
But i would recommend you spend the $150 to upgrade to VDJ Pro.. i did because the software that came with the the controller got annoying because i couldn't do very much with the LE version of the software...
geposted Tue 23 Feb 10 @ 9:04 pm
