Whats up Fam?? I have virtualdj 5.0 how do i get my samplers to play automaticly????? &&&&&
I recorded myself for bout an hour, then tried to load that track so i could critique...... & only bout 45 sec of the recording loaded, what do i do &&&&&&&
My music is kinda unorganized & unlabeled (..... i know.....smh.... not good for a dj) but how could i fix that??????
Thanks
Thanks
geposted Thu 25 Feb 10 @ 7:20 pm
To start with 5.0 dawg? Really do think it's time you upgraded your software to the latest 6.05
geposted Thu 25 Feb 10 @ 7:24 pm
why upgrade if you can still rock the party????? does that cost to upgrade to 6.0? if so it will take time cause its other pieces i wanna add on.....Im learning as I go Daaawwwwg work wit me
geposted Thu 25 Feb 10 @ 7:43 pm
its free FAMZ just go to the download section and run it!! Should be all good after that!! Oh you will have to re-tweek it though and you will have to get used to the new interface!!
geposted Thu 25 Feb 10 @ 9:31 pm
tweak yes, interface no...just choose the vdj 5 interface and hey presto...
geposted Fri 26 Feb 10 @ 1:59 am
Suggest you install in a seperate folder so you can revert back to v5 if you have issues - not saying you will but covering your ass when you are a professional is a must ;-)
I haven't looked back since moving to 6 and currently runing 6.0.5 which is the latest Pro build.
Downlaod and see.
Cheers,
Roy
Downlaod and see.
Cheers,
Roy
geposted Fri 26 Feb 10 @ 5:25 am
@djlivstrong, I'm on 5.2.1 doing 6 -7 hours of video works flawless for me.
geposted Fri 26 Feb 10 @ 5:33 am
The upgrade to v6 is free.
geposted Fri 26 Feb 10 @ 12:27 pm
Thanks All of ya'll............. ya'll are the best. I'm going to check out 6.0, but is there a way to erase my database and reload
geposted Fri 26 Feb 10 @ 11:06 pm
