What should I do to remove duplicated tracks. To further my query, there are some dupes that dont work. e.g. Same exact file name but one does not work.
geposted Fri 26 Feb 10 @ 10:50 am
Im sure this topic has been discussed. If anyone could link me up, that would be fine.
geposted Fri 26 Feb 10 @ 11:03 am
Just going through your library manually is the best way .... to be honest you really should keep your database clean from day 1 and that would avoid what you have to do now!
geposted Fri 26 Feb 10 @ 11:27 am
Cool. Ill do it as i go. What causes this?
geposted Fri 26 Feb 10 @ 11:30 am
Dunno, every one is different. In VDJ options you can go to the browser tab and select database check then clean. That should help erase all the duplicates that don't exist.
Keith
Keith
geposted Fri 26 Feb 10 @ 11:33 am
You can always right-click on an individuual track and select "remove From Database" that way search will never pick it up again.
Cheers,
Roy
Cheers,
Roy
geposted Fri 26 Feb 10 @ 11:50 am
Thanks guys. Ill be sure to try these suggestions.
geposted Fri 26 Feb 10 @ 1:31 pm
