Hi all,
I recently started using the Mac version, so I converted my database file to reflect the mac file locations and it worked perfectly. However I noticed the files scanned in VDJ windows all have the correct bitrate but any scanned in Mac VDJ have the bitrate blank.
It's sort of helpful as I have rescanned loads of tracks to 320kbps so it's good to see the ones redone in the browser.
In file infos, they come up as 0kpbs
Can someone else please check this for me before I submit a ticket.
Ta
Keith
Ta
Keith
geposted Fri 26 Feb 10 @ 2:55 pm
mate how did you rescan to 320 bitrate.do this make a difference to quality of playback.did you try play song to get what you want.try deleting bitrate in file info then rescan
geposted Sun 28 Feb 10 @ 6:03 am
