I bought an Optoma Pro150s DLP projector and now i am looking to buy a screen. What screen size should i get.. Then its the surface.. Matte white, High Contrast matte white, Video Spectra 1.5 and High Power.
This is the projectors specs
Aspect Ratio 4:3 (Native) 16:9, 16:10
Brightness (ANSI Lumens) 2800 ANSI Lumens
Contrast Ratio 3000:1
Display Type 0.55" DMD DLP
Resolution (Native / Max) SVGA (800 x 600) HD (1920 x 1080)
Video Compatibility NTSC, PAL, SECAM, HDTV (480i, 480p, 720p, 1080i, 1080p)
Projection Lens F = 2.4 ~ 2.6
f = 21.8 x 24.0mm
Number of Colors 1.07 Billion Colors
Size Dimensions (WxHxD) 11.3in. x 4.0in. x 7.6in.
(28.7cm x 10.16cm x 19.3cm)
Weight 5.0 lbs. (2.27 kg)
Connectivity Inputs 1 x VGA D-Sub 15pin
1 x S-Video
1 x Composite
1 x Stereo Mini Jack
Outputs 1 x VGA D-Sub 15pin
Audio 1 x 2W Mono Speaker
Control 1 x IR Remote
1 x RS-232
Operation Power Supply 100 ~ 240 V / 50 ~ 60 Hz
Power Consumption 255W (Bright Mode)
230W (Normal)
1W (Standby)
Audible Noise 28 dB (Normal)
30 dB (Bright Mode)
Operating Temperature 41°F ~ 104°F (5°C ~ 40°C)
Operating Humidity 85% (Maximum)
Projection Lens Lamp Type 185W UHP
Lamp Life 4000 hrs (Normal)
3000 hrs (Bright Mode)
Projection Distance 3.3ft. ~ 32.8ft. (1.01m ~ 10m)
Projection Mode Front, Rear, Ceiling, Desktop
Projection Screen Size (Diagonal) 23in. ~ 300in. (58.42cm ~ 762cm)
Throw Ratio 1.95 ~ 2.15:1
Optical Zoom 1.1:1
Vertical Keystone Correction +/- 40 Degrees
Brightness Uniformity 85%
Other H-Sync Range 15 ~ 91 kHz
V-Sync Range 24 ~ 85 Hz
Features Kensington Lock
Im going to buy 2 cables. One is a DVI to VGA and the other is VGA to Component ( For the satelite box to the Projector to watch PPV boxing matches). Im a hardcore boxing fan.
f = 21.8 x 24.0mm
1 x S-Video
1 x Composite
1 x RS-232
230W (Normal)
1W (Standby)
30 dB (Bright Mode)
Optical Zoom 1.1:1
geposted Sun 28 Feb 10 @ 8:00 pm
Sorry no input from lack of experience with such equipment however am interested to see where you end up and possibly view a video.
geposted Mon 01 Mar 10 @ 1:37 pm
