I have a two part question here and would like to hear what others have to say.
I like to use fader start and I bought a FCU8-USB Fader Control Unit but have not
been able use it. I use the latest version of VDJ Pro and Pioneer DJM 3000 mixer.
Any help will be much appreciated.
My 2nd question is about the Data Field Columns. In today’s music we have many
versions and remixes of a hit song. I think it will be very useful to have “version” added
to the Data Field Columns so that the user can fill in his choice. Any suggestions please.
Thanks
Thanks
geposted Mon 01 Mar 10 @ 10:30 am
I use the "comments" field for the version name. It also reads that field from the tag when adding to the database.
Keith
Keith
geposted Mon 01 Mar 10 @ 11:14 am
Keith
Keith
I use the "comments" for personal use, like 5 stars to 1 star, 5 stars being top hit to 1 star, play it only on request.
geposted Mon 01 Mar 10 @ 11:50 am
Better use an other character than the '*' - because VDJ uses it as wildcard ;-)
I personally use the '+' symbol.
Greets, Heiko
Greets, Heiko
geposted Mon 01 Mar 10 @ 11:53 am
Hi Heiko,
Thanks for the tip, will end it.
Greetings from Switzerland
John
geposted Mon 01 Mar 10 @ 2:10 pm
It's designed for use with BPM Studio and is not natively supported by VirtualDJ.
However, if it's MIDI capable or USB HID, then you should be able to create a definition and mapping for it: https://virtualdj.com/wiki/VDJscript.html
geposted Mon 01 Mar 10 @ 2:13 pm
Hi, Thanks. My knowledge on computers is limited, can you please walk me thru.
geposted Mon 01 Mar 10 @ 2:27 pm
First you would need to see if it is a MIDI or HID device. If not, then it will not be possible to utilise it (Atleast not without special 'hard' coding by the dev team.)
Make sure that you have no other peripherals/devices connected to your computer except the fader start box.
Go to Windows Control Panel -> System -> Hardware
Look under Sound, video and game controllers - If you see the device listed, or if you are using Windows XP and you see 'USB Audio Device' listed, then it is MIDI capable.
Otherwise, look under Human Interface Devices. If you see it listed there, it is HID capable.
NOTE: If you upgrade to a MIDI capable mixer, then you would be able to map the volume sliders to perform fader start.
geposted Mon 01 Mar 10 @ 7:20 pm
I'm pretty sure all the Alcatech stuff is proprietary, I know the RCP controllers definitely don't work with any other software.
Keith
Keith
geposted Tue 02 Mar 10 @ 1:57 am
Hi, I pluged only the faderbox in the USB and it shows only in USB Controller. Under Human interface device I see "HID Compliant consumer control device, but it says
Manufacturer: Microsoft
I don't think this is the faderbox because when I unplug it, it's still there, or am I dead wrong and what should I do next.
Thanks for your halp.
John
geposted Tue 02 Mar 10 @ 8:22 am
You will probably find that is your mouse or keyboard.
If it were the fader box, it would disappear when you unplug it.
Unfortunately it looks like it is proprietary and only supported by BPM Studio.
geposted Tue 02 Mar 10 @ 12:22 pm
Afaik - the controller is a proprietary protokoll only usable in BPM Studio. It's something like a coded serial protocoll. I asked about the controller facts about 1 year ago because a friend of mine changed to VDJ pro and wants to use the controller with it.
As Alcatech reported there is no chance to map it.
Greets, Heiko
Greets, Heiko
geposted Tue 02 Mar 10 @ 12:28 pm
Greets, Heiko
Greets, Heiko
Thanks for all the help. I don't even know if its supported in windows 7. I have written to BPM Studio and will post their reply. Just for your info, I do use BPM Studio with Fader strat, this is my main programme, I use the VDJ only for mixing, and sometimes for background, lounge and chillout music.
geposted Tue 02 Mar 10 @ 3:42 pm
I can confirm I have tried the RCP controller and it certainly does not work with VDJ 6 so I guess the fader start box will be the same. Alcatech deliberately designed their gear to be this way.
I gave up on BPM Studio 2 years ago due to non-development, expensive repair costs, shocking customer service and 160 Euros to update BPM Studio to work with Vista or 7. I'm really amazed these people are still in business to be honest!
Keith
Keith
geposted Tue 02 Mar 10 @ 3:57 pm
Keith
Keith
I have a Pioneer mixer, I don't want to buy a midi controller just for fader start, is there a feder start box which I can buy and will work with VDJ. The one I have is from BPM Studio and it does not work with VDJ.
Thanks
geposted Wed 03 Mar 10 @ 6:50 pm
