Hi , i use the mono seperated option so my left channel exit goes to the amplifer and the right channel goes to my headphone . It worked fine but today that changed .
Now it sends the master out to left & right , so i can't pre-listen anymore :s .. Checked the options & cables and everything seems right . I also still can hear the music through amp & headphones while my (playing)deck fader is shut and the pfl button is switched to the other deck ... The fader works again if i turn the cue button at the volume section all the way right , but then the volume doubles when i press the pfl button of that channel :s ( it is al the way left from standaard ?)
I tried a few little things like changing the settings to simple output , closed program , restarted and changed it again , also tried reinstalling VDJ but that didn't help ...
Ow yeah , and the program refuses to load some songs ( while the next or previous songs from the same CD rip works fine .. )
I am using a laptop with windows 7 and no external soundcard
and i am totally confused
geposted Mon 01 Mar 10 @ 12:48 pm
what version are you using?
geposted Mon 01 Mar 10 @ 2:15 pm
o yeah i forgot to mention that , i am using vdj version 6.0.2
geposted Tue 02 Mar 10 @ 3:04 pm
